Test
  • 2 Respuestas
  • 3198 Vistas
  • 21641
Test
« en: 29 de Junio de 2021, 12:55:38 pm »
Mission Overview:
Cobra6  (AI STRIKE)
Package #:   1447  (Air Interdiction)
Pkg-Mission:   Strike Ta-Pang Bridge
Target Area:   8 nm east of Kang-Shan Town.
Time on Target:   09:36:00z
Sunrise:   21:35:29z (05:35:29l)
Sunset:   10:16:30z (18:16:30l)
Be advised: Starting at 11:00:00, our ground forces will be making a major push towards Kao-Hsiung.
Army intelligence reports the PRC 191st Tank Battalion is advancing towards Tai-Pei and will be forced to cross Ta-Pang Bridge. We hope to destroy the bridge before the enemy is able to get across, and substantially delay their attack.
Intelligence reports the highest impact targets are:
 -- Bridge   --   100% operational
Pilot Roster:
Callsign:      Flt Lead:      Wing Two:      Elem Lead:      Elem Two:
Cobra6      2Lt. Skorp      Lt. Alexandrow
Tornado3      Col. Koslow      Lt. Nikiforow
Package Elements:
x  = Primary Flight
Callsign:       Flt #:      Role:      Aircraft:      Task:
Cobra6      1448  ( x )      AI STRIKE      2 F-16AM ROC       Destroy Bridge at target site
       T/O: 09:17:08z      Push: 09:30:22z      Tgt: 09:36:00z      IFF: M124/4/161/27104-5/31504-5
Tornado3      1449      ESCORT      2 Mirage 2000-5F       Protect package elements from enemy aircraft
       T/O: 09:13:25z      Push: 09:28:22z      Tgt: 09:34:00z      IFF: M124/4/161/27110-1/31510-1
Air-to-Air Threats:
Enemy CAP aircraft are likely to be operating within operation area.
Surface-To-Air Threats:
There are no known enemy air defense assets along your flight path.
#:   Desc:   Time:      Dist:      Head:      Cas:      Alt:   Action:   Form:   Comments:
1   Takeoff   09:17:08z      --      --      --      --   Climb immediate   Wedge   Takeoff
2   --   09:21:02z      24.6      303      275      22.0M   --   Wedge   --
3   Holding Pt   09:22:57z      14.7      174      335      22.0M   --   Wedge   Hold (Departure: 09:28:57z)
4   Push   09:30:22z      9.8      174      300      22.0M   Descend immediate   Wedge   Rendezvous with package
5   Pre IP   09:32:46z      19.2      238      380      17.0M   Climb immediate   Wedge   --
6   IP   09:33:54z      9.0      237      375      18.0M   --   Wedge   --
7   Strike   09:36:00z      16.8      237      375      18.0M   --   Wedge   Attack target
8   Turn Pt   09:38:32z      20.3      65      375      18.0M   Climb delayed   Wedge   --
9   Split   09:42:32z      30.3      59      355      21.0M   Descend delayed   Wedge   Depart from package
10   Land   09:44:30z      15.7      46      360      --   --   Wedge   Land
11   Land   --      --      --      --      --   --   Wedge   Land (Alternate)
Comm Ladder:
Agency:      Callsign:      Uhf [Chnl]:      Vhf [Chnl]:      Notes:
Intra-Flight:      Cobra6      --      138.400 MHz [15]      Flight Management Comms
Guard:      None      243.000 MHz      121.500 MHz      Distress / Emergency
Common:      None      339.750 MHz [14]      123.500 MHz [14]      Advisory / UNICOM
Base Ops:      None      --      --      Homeplate Operations
Check-In:      Dragnet5      356.600 MHz [5]      --      AWACS: Global Check-In
Tactical:      Dragnet5      372.025 MHz [6]      --      AWACS: Package Comms
Tanker / Aar:      Copper2      249.125 MHz [13]      --      Boom Operator
Dep Atis:      Hua-Lien ATIS      --      --      Departure Airbase
Dep Ground:      Hua-Lien Ground      239.900 MHz [2]      --      Departure Airbase
Dep Tower:      Hua-Lien Tower      239.950 MHz [3]      122.800 MHz [3]      Departure Airbase
Dep Departure:      Hua-Lien Departure      239.500 MHz [4]      --      Departure Airbase
Arr Atis:      Hua-Lien ATIS      --      --      Recovery Airbase
Arr Approach:      Hua-Lien Approach      239.500 MHz [4]      --      Recovery Airbase
Arr Tower:      Hua-Lien Tower      239.950 MHz [3]      122.800 MHz [3]      Recovery Airbase
Arr Ground:      Hua-Lien Ground      239.900 MHz [2]      --      Recovery Airbase
Alt Atis:      Hua-Lien ATIS      --      --      Alternate Airbase
Alt Approach:      Hua-Lien Approach      331.500 MHz [10]      --      Alternate Airbase
Alt Tower:      Hua-Lien Tower      331.025 MHz [11]      125.900 MHz [11]      Alternate Airbase
Alt Ground:      Hua-Lien Ground      331.250 MHz [12]      --      Alternate Airbase
Iff
GENERAL:
Initial STAT Settings:      Modes Active: M124      Codes:      M1: 61      M2: 7104      M3: 1504
M4 Validity Time (Until):      Key A: Day2 00:00z      Key B: Day3 00:00z
IFF Policy:      M1: per team      M2: per aircraft      M3: per aircraft
Code Change Setting:      POS/TIM
TIME EVENTS:
Rot/day:      10:00z      11:00z      12:00z      13:00z      14:00z      15:00z      16:00z      17:00z      18:00z      19:00z      20:00z      21:00z
M1:      24      72      22      51      63      30      13      03      60      20      10      51      01
M3:      24      2530      1330      0204      0204      2454      5504      5354      2130      1704      3704      1354      2054
M4:      1      A      A      A      A      A      A      A      A      A      A      A      A
POS EVENTS:
Ingress: M4 / WOF4      Egress: M124 / EOF9
Cobra6      -- Cobra61 --      -- Cobra62 --
510 x 20mm M61      510 x 20mm M61
2 x AIM-120B AMRAAM      2 x AIM-120B AMRAAM
2 x AIM-9M Sidewinder      2 x AIM-9M Sidewinder
2 x GBU-31(v)3/B /AP      2 x GBU-31(v)3/B /AP
2 x Tank 370gal      2 x Tank 370gal
1 x AN/ALQ-131(v)      1 x AN/ALQ-131(v)
1 x AN/AAQ-28(v)      1 x AN/AAQ-28(v)
Tornado3      -- Tornado31 --      -- Tornado32 --
250 x 30mm DEFA 554      250 x 30mm DEFA 554
2 x Mica IR      2 x Mica IR
2 x RPL-541/542 (AA)      2 x RPL-541/542 (AA)
4 x Mica EM      4 x Mica EM
Conditions @      Take Off:      Target Area:      Landing:
Situation:      Sunny      Sunny      Sunny
Wind:      92 deg @ 2 kts.      297 deg @ 0 kts.      92 deg @ 2 kts.
Visibility:      59km      59km      59km
Temp:      14 deg C.      15 deg C.      14 deg C.
Cloud Base:      32,000 ft MSL base      32,000 ft MSL base      32,000 ft MSL base
Con Layer:      34,000 ft MSL base      34,000 ft MSL base      34,000 ft MSL base
Callsign:         Station Area:
Dragnet5 (AWACS):   1 E-2C      Friendly AWACS aircraft will be operating 79 nm east of Hua-Lien. Available for air detection and warning.
Copper2 (Tanker):   1 KC-10      Friendly tankers will be operating 81 nm east of Hua-Lien. Available for mid-air refueling.
Note: Friendly aircraft may be operating in the area.
Distress call:
For aircrew in a hostile area, prior to ejection, transmit on the working frequency: “MAYDAY” (three times); call-sign; and position in relation to BULLSEYE.
Combat Search and Rescue:
SAR helos are available within 30 km of FLOT. In case of shoot-down, mark closest coordinates of the survivor’s position and report the incident to the CSAR assets. Establish radio communication with survivor and execute the On Scene Commander procedures.
Alternate airfield:
Hua-Lien, 3 nm south of Hua-Lien
Sanitise yourself and review your evasion plan of action.
Good Luck!
Mission Overview:
Cobra6  (AI STRIKE)
Pilot Roster:
Package Elements:
x  = Primary Flight
Air-to-Air Threats:
Comm Ladder:
Iff
GENERAL:
TIME EVENTS:
POS EVENTS:
Distress call:
Alternate airfield:
Good Luck!
Mission Overview:
Cobra6  (AI STRIKE)
Pilot Roster:
Package Elements:
x  = Primary Flight
Air-to-Air Threats:
Comm Ladder:
Iff
GENERAL:
TIME EVENTS:
POS EVENTS:
Distress call:
Alternate airfield:
Good Luck!
Litus
  • 1463
  • No estoy de acuerdo
    • Comando Aleph
Re:Test
« Respuesta #1 en: 01 de Julio de 2021, 23:27:00 pm »
Precio?
Re:Test
« Respuesta #2 en: 02 de Julio de 2021, 07:32:24 am »
Vendo Opel Corsa.
