Ikaros Theater 4.1.1
  • 5 Respuestas
  • 3183 Vistas
  • 20963
« en: 07 de Enero de 2017, 08:30:07 am »
IKAROS Theater v4.1.0
for Falcon BMS 4.33 Update 3
The Development Team of IKAROS Theater is pleased to announce its next version 4.1.0,
which is a stand-alone package, independent of any older version.
Apart from the included Changelog, please note the following:
- No airbases are updated, other than LGSA (Souda), LGBL (Nea Anchialos) and LGAD (Andravida) which include new features. All other airbases are the same as from IKAROS v3.2.0. It is expected that the next version of IKAROS will include updates in many other airbases.
- This version of IKAROS includes a working Campaign named "Exercise Poseidon". To use it, please make the appropriate choice in the included "Ikaros Settings" utility.
Download the 2.3GB ZIP package at the Main site or the Mirror Site
Installation Instructions:
1) Unzip the package anywhere in you PC, which includes the two files: "Setup Ikaros Theater 4.1.0.exe" and "data.file"
2) Run the Installer file "Setup Ikaros Theater 4.1.0.exe" and follow the on-screen info. Volume-up your PC speakers during installation...
3) After the installer finishes, read the "InstallationNote.txt" which opens automatically with your default text editor, and make the indicated edits in the "Falcon BMS 4.33 U1\Data\Terrdata\theaterdefinition\theater.lst" file.
Enjoy!
Below you can find a small update for Ikaros v4.1.0. The update will patch the theater to v4.1.1
This fix addresses issues with CTDs which was periodically reported around Souda and Nea Anchialos airbases. Also, it addresses other bugs as well.
You need to have installed Ikaros v4.1.0 before applying this fix.
To install it, simply unrar the file and copy the Add-on Ikaros to C:\Falcon BMS 4.33 U1\Data
All TEs which were made in v4.1.0 are compatible with v4.1.1
Ikaros 4.1.1
« Última modificación: 20 de Febrero de 2019, 09:31:12 am por Skorp »
  • 3419
Re:IKAROS THEATER v4.0.0.0
« Respuesta #1 en: 07 de Enero de 2017, 10:01:27 am »
Buenísimo el teatro, y eso que aún no está completado del todo.
A darle caña a Erdogan  :pulgares: :roll:
Fresco
  • 20963
« Respuesta #2 en: 14 de Enero de 2017, 09:49:24 am »
Un "regalito" de JanHas    :P
The first PXIII model and skin for 337 Mira is almost ready for release (tomorrow). It's for the Ikaros theater, but can be used for the standard BMS 52+ & CFT as well
 :wc:
  • 12742
« Respuesta #3 en: 14 de Enero de 2017, 11:01:07 am »
Que ganas de que lo saquen con campaña jugable.  :pulgares:
  • 20963
Re:IKAROS THEATER v4.1.0
« Respuesta #4 en: 26 de Junio de 2017, 14:56:25 pm »
Post actualizado a la nueva versión v4.1.0.
Un saludo
  • 20963
Re:IKAROS THEATER v4.1.1
« Respuesta #5 en: 10 de Octubre de 2017, 06:30:34 am »
Update 4.1.1 disponible
