Balcanes para 4.33 U3
  • 64 Respuestas
  • 12304 Vistas
  • 21037
Re:Balcanes para 4.33
« Respuesta #15 en: 23 de Noviembre de 2015, 12:58:11 pm »
Fresco, esto es ya la buena o solo es una beta?
  • 3434
« Respuesta #16 en: 23 de Noviembre de 2015, 14:38:07 pm »
Es una beta "avanzada". Proximamente sale la versión final, con los objetos de Nove y los aeródromos reales. Pero esta versión mola, la verdad...
Fresco
  • 21037
« Respuesta #17 en: 23 de Noviembre de 2015, 19:23:02 pm »
Juder que fotacas!  :shock:
  • 21037
« Respuesta #18 en: 20 de Febrero de 2016, 07:40:04 am »
Nueva torre en Amendola
Y más instalaciones nuevas
Y los nuevos hangares en construcción...
:pajillero:
« Última modificación: 20 de Febrero de 2016, 07:42:35 am por Skorp »
  • 21037
« Respuesta #19 en: 03 de Marzo de 2016, 11:25:29 am »
Fix solucionando alguas cosillas
Por Cougar 56th
Hey guys,
Over the past month/month and half I have been trying to fix some of the minor issues with the Balkans such as objective placements and the issue with vehicles on the runway. While I am not 100% sure I fixed the vehicle issue, I did move some vehicle AAA point data around on Gio Del Colle to try to get it to not put vehicles on the airfield.
Along with the vehicle fix, I moved some objectives around/re-positioned some objectives so they looked like they were in the correct places. The Ports probably the most noticeable. You would see the entire port or partial port on the land or in the sea, not positioned correctly at all.
Also the dogfight module was broke where it would only allow you to fly the red or blue team. Now all 4 teams are available.
Tree fix was added to this update as well.
If you have started a campaign, unfortunately, because I had to update the .cam files, I would recommend you start a new campaign...sorry, hopefully I will not have to mess with those files again.
I will eventually re-build the Balkans Theater so it is only one installer, but for now, this will do.
Balkans 4.33 Update 1
  • 10836
« Respuesta #20 en: 03 de Marzo de 2016, 11:37:59 am »
Apuntado para actualizar.  :pulgares:
  • 5104
« Respuesta #21 en: 03 de Marzo de 2016, 12:01:05 pm »
<De momento me conformo con que funcione korea.. XD
  • 21037
« Respuesta #22 en: 08 de Abril de 2016, 07:25:12 am »
Update para BMS 4,33-1
Hey guys,
I updated the Balkans for BMS 4.33 to make it compatible with Update 1. Please note that it is a completely new download and not a patch for the Balkans theater for 4.33.0 and the Update for Balkans 4.33.0....completely fresh new install. Just make sure you install it on the Falcon BMS 4.33 Update 1 install.
Here is the link to go get the theater.
Balkans 4.33.1 for Falcon BMS 4.33 Update 1
  • 12750
Re:Balcanes para 4.33-1
« Respuesta #23 en: 08 de Abril de 2016, 15:00:09 pm »
Bajando  :pulgares:
Debugger
  • Canelón
  • 20
« Respuesta #24 en: 08 de Mayo de 2016, 13:07:59 pm »
Hola a todos.
Han sacado una nueva actualización, la 4.33 1b balcanes.
Si tenéis el teatro instalado ya revisar que fecha tiene e instalar solo los hotfix.
http://www.bmsforum.org/forum/showthread.php?23469-Balkans-Theater-of-Operation-for-BMS-4-33
Un Saludo.
Debugger
  • 21037
« Respuesta #25 en: 08 de Mayo de 2016, 18:48:28 pm »
Bajando el hotfix 2
Thx Debugger :pulgares:
Debugger
  • Canelón
  • 20
« Respuesta #26 en: 09 de Mayo de 2016, 18:14:16 pm »
Quiero volar en Balcanes, pero no me aparecen misiones de entrenamiento y no tengo ni idea de como funciona el Editor de misiones. Un alma caritativa y que se curre alguna y me la pueda pasar.???  :(
Un Saludo.
Debugger
  • 3434
« Respuesta #27 en: 09 de Mayo de 2016, 19:34:42 pm »
Joer Debugger, di al menos de que quieres la misión ¿bombardeo con hierros, con GBU, munición GPS, combate AA con Slammers, training de navegación con mal tiempo????
Dame pistas y te preparo algo rapidito
Fresco
Debugger
  • Canelón
  • 20
« Respuesta #28 en: 09 de Mayo de 2016, 19:43:17 pm »
Gracias Fresco por el ofrecimiento.
Podría ser un combinado de navegación + refueling + bombardeo con GBU's o MK82 y si ahí que soltar algún Harpom a algún sa2 pues no pasa nada.
Gracias Anticipadas.
Debugger.
Un Saludo.
Debugger
  • 21037
« Respuesta #29 en: 09 de Mayo de 2016, 20:22:01 pm »
  :bate:
Un Harpoon a un SA-2?
